My Sony Bravia XR-85X90K 3yr old tv will not turn on. I’ve checked the power to the outlet and the power cord and both check out fine. Had anyone had a similar experience and if so, how did you fix the problem?
If your TV is still under warranty get in touch with whoever sold you it and organise for someone to
come out and assess what the problem is and wht repair is necessary.
If it is not under warranty then you will need to find out if it financially viable to get it repaired
otherwise a new TVmay be better value.
Where did you buy the TV and what ws the length of warranty you were given?
Hello probably the TV software ,in meny case ist the problem
