Hi all,
I 've bought a Xperia U and I can't turn off the demo player which starts every time screen is supposed to go black. When I turn it off manually next time I restart the phone it is there again! Any ideas in how to erase or uninstall it completely?
i type *#*#73556673#*#* when my phone cennected to charger ! do it . but i suggest you read this first :
http://talk.sonymobile.com/thread/51012?start=0&tstart=0
if my answer is correct or Helpful, mark the Correct Answers & Helpful Answers please
Cehck the thread above
And you can't uninstall the retail demo app until you root your phone
How can I remove the demo video in Xperia Z Ultra, it keep pop up and i feel annoying with that. Is there any solution to solve this problem?
HI there since you wanna delete those demo videos ...you have two ways........
1)connect your device to your system(turn on usb debugging and allow mook location ticked) then open your device from my computer then just search demo (in search box type demo.mp4)and delete those videos...
2)your phone would have a preloded app for file browsing using that app just goto videos in the sd card and delete those videos.........
