Good day.
sorry for my English(( google translate ))
I became a happy owner of SE j108i Cedar.
But I was disappointed by the fact that when I try to install any Java application (the side, not coming bundled with the phone, embedded applications are run), he said a "operation failed" (Ошибка при выполнении операции).
is not a bug of new applications in the previous phone it worked
software forcibly updated with SEUS, did not help.
rolled back to an earlier firmware r7da056, also did not help.
help pliz
What should I do more? ((
Yeah, it's normal to have an empty list of Client certificates, so don't worry about that.I can only suggest that you try re-installing the software once more and if this doesn't work, you can try formatting the memory card as I assume these files are being downloaded/transferred to the card.You can also try transferring the files to the phone memory and see if they can install from there.
YYYEEEESSS!!!
miracle happened))
rejected memory card and apps installed correctly) bugs memory card??
THX very much))
No problem.Thanks for the beer!! Yes, memory cards can get buggy, so best to format it.
