Good day.
sorry for my English(( google translate ))
I became a happy owner of SE j108i Cedar.
But I was disappointed by the fact that when I try to install any Java application (the side, not coming bundled with the phone, embedded applications are run), he said a "operation failed" (Ошибка при выполнении операции).
is not a bug of new applications in the previous phone it worked
software forcibly updated with SEUS, did not help.
rolled back to an earlier firmware r7da056, also did not help.
help pliz
What should I do more? ((
Yeah, it's normal to have an empty list of Client certificates, so don't worry about that.I can only suggest that you try re-installing the software once more and if this doesn't work, you can try formatting the memory card as I assume these files are being downloaded/transferred to the card.You can also try transferring the files to the phone memory and see if they can install from there.
Have you tried a master reset?
yes of course)
you on duty around the clock on the site))?
Have you downloaded these Java apps/games directly from your phone's browser, or transferred the .jar/.jad files from your PC to the phone? Or makes no difference either way? I don't work for SE, so "duty" is the wrong word.
sorry - google translate))
I transferred the .jar/.jad files from my PC to the phone
Tryed install application with MyPhoneExplorer no any of the results
In SE PC Companion I not found similar function
Well, you shouldn't need to transfer these files via any application.Simple file transfer by copy/paste should be sufficient.As for the Java certificates, check in your phone: Main menu--Settings--General--Security--Certificates--Java Certificates: Here check that you have Sony Ericsson, Geotrust, Thawte and VeriSign, and that they are all enabled.When you re-install the software with SEUS or perform a phone repair with PC companion/suite, all the certificates should also be re-installed as part of the software re-installation.
just tried downloaded thoose
Java apps directly from phone's browser - same mistakes
