Hello everyone:-)
I have Active from like two days, and I cannot find timer, stopwatch and possibility to writing short notes. And on the specyfications I see that it is possible. I have read manual, but I cannot find those things. Maybe its stupid question, but still it is a question:smileywink:
Could You please help?
best regards
K.
hi @kabar24 for the timer go to any homescreen and tap and hold the screen a widget tray will popped up scroll down to timer and u will get it for the other two u have to download it from the market...!!
Thanks Man:smileyhappy:
no problem..do you need the link to download the other apps..??!;-) and don't forget to mark my answer as correct and helpful..!!
