I bought a Griffin SmartTalk mic to use with the FM radio on my Arc S and Shure headphones. Unfortunately when I plug it in the phone reports that it is an unsupported accessory. Does anyone know of a mic that will work with the Arc? Preferably with a button.
Thanks, Jamie
I think you might find your answer here: http://talk.sonyericsson.com/message/154264#154264
What do you think about this forum? Let us know by doing this short survey.
Thanks.
