Why does the XPERIA mini pro not have the old inbox, outbox and sent boxes like phones used to be?
Jack
check Go SMS Pro
or
or
or
also check out Handcent
bc it's an smartphone, and all smartphones are like that, but check the market there might be an app for that
it's easier to find apps on your computer
market.android.com
check Go SMS Pro
or
or
or
Thank you, I will have a look around the markets.
anytime
I have downloaded an app which does the job perfectly.
Many thanks for your help.
Jack
anytime, make sure you mark this thread answered/or check the correct answer, so other users can look up this thread and find the solution
Just marked the answer I used as correct.
Thanks again, signing off now.
