The screenshot says it all! While installing an app the, title( in this case note the title Truecaller ) is aligned slightly below its original position. Does any one has this problem and should i take it to service center ? Thank you.
Topic edited by Rickard
I have the same alignment as you when i install an APK manually so there's nothing wrong with your unit but i agree that it looks a bit odd to have the text aligned that way. I've forwarded it as feedback internally but as there are no more Android updates planned for SP i doubt that this will be changed.
Then Please suggest me! what do i do? If this is a bug every XSP has then it will be solved in an update and i dont think every XSP owners has this problem...:/
It looks like that when you install an APK manually using for example a file manager so there's no need to send your phone to service. If you install an app using Google Play it will look differently:
You are right! It looks great while installing from Play but isnt it odd to look like the one above while installing an app manually? Ive reinstalled the software using PC companion, no use...:smileyrolleyes:
It should actually look like this
