When I updated my mobile in kitkat my memory card desable and sefe to remove again and again also my camera has been failed to initialized. so what can i do?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
First of all I would suggest that you remove your SD card, restart your device and put the SD card back in. Then go to settings > apps > all > camera > clear data. Restart your device again and see if it works better.
Thank you for Solution.
My camera was ok. But External Memory Problem is still there. when I share any file in my memory card through WI-FI Direct my memory card is remove again and again.
So, What can i do for fix theme?
My video recording is not working.
Please suggest
