I want to buy a hardcase for phone which the type is T2 Ultra. But, the store only mentioned T2 in their list. Is it the same type with T2 Ultra or different? I'm afraid that I might make a mistake to buy this case. Thank you for your help.
Hi @Krisdhew, welcome to our forum!
That sounds very odd as there is no Xperia T2, only Xperia T2 Ultra and Xperia T2 Ultra Dual (both are the same size however).
Have you tried contacting the store or the seller and checked with them if they have any further information as to why the named it Xperia T2? If you haven't done that I recommend doing so, just to make sure that you don't receive the wrong case for your device!
Let me know how it goes!
