After the last update ( software n : 2.1.A.0.435) my phone doesn't make contacts sync nor with Google account neither with SE, when I try to make it manually everything looks OK but when I open my accounts on PC there is no Change!!!
Before the last update it was working perfectly, I tried many times and no changes.
Did any one face this problem??
Thank you , but I don't want to input a new contact in my Gmail Account I just want to bring my phone contacts to my Gmail account
if you don't have any contacts saved on either Sony Ericsson nor Gmail, theres nothing your phone can sync to.
Do you mean that I cannot export the contacts from the phone to the Gmail account??
I have contacts in the SE account and I managed to sync with my phone.
I'm a bit confused on what you're having issues with, yes you can transfer your contacts on your X10 to your Google account
I have just read this thread and am probably going to state the obvious... you do have within Menu>Settings>Accounts & Sync the Background Data and Auto-sync ticked? And you do have a data connection running on the phone, either wifi or 3g.
Thanks for your patience :smileyconfused:, the problem: when I make sync my phone doesn't send my contacts to my Gmail account
It is because your PHONE contacts is different from GMAIL contacts, since there is no GMAIL contacts in your phone, there will be no contacts sync-ed to your gmail account.
exactly, you need to
1) either add manually or sync your contacts to your phone
2) once your contacts are on your phone you can sync them to Google/Gmail
or
you can enter them manually to your gmail contacts and then sync your phone
Yes , I do.
Sorry I'm little bit confused, briefly : I have no contacts in my Gmail account , I have almost 300 contacts in my phone ( numbers, Emails... etc) I'm trying to sync between them to transfer the contacts from my phone to my Google account , I tried everything but still when I open contacts in Gmail (in PC) I don't find anything.
