or you can use this widget it's quite nice
Power Control
when you say 3G are you referring to the data plan?
Yes....the 3G data plan
there are myriad options
settings -> wireless & networks -> mobile networks > uncheck enable data
or use a widget
on the homescree -> menu > widget > data
Power Control
thanks a lot for the quick and effective reply!!
Anytime
