Basically, with the Android software I got from AT&T had a feature I really liked about it. Now this is odd to say, but what I liked was that the text notifications was a smiley face. In this latest version of Android, it's just an envelope.
So what I'm wondering if there is some way I can change it back to that smiley face in the status and on the lock screen? If I could do this, then it would probably save me some trouble as I'm still pondering about downgrading.
here are some options
WidgetLocker Lockscren its one of the best
(make sure to mark the correct and helpful answers)
ICS Lockscreen HD
This is another great option but you need to have
a LOT of people like this one, it is really amazing
Lucent Lock Screen
ICS Lockscreen HD
Lucent Lock Screen
