What is wrong here . . .
When my T is locked I got this screen, I understand all but what the *^##@ is the text under the date ? aalqm pplplaq
Maybe something in my google profile or somewhere else . . . what is it cause I wanna get ride of it . . . please help
It's not an app. Go to settings>security and go to the second, something like "user data" ( on .140). There you can check a box, whether show or hide a small text on the lockscreen.
it might be some app acting up
try the basic > restart your phone
also disable any intrusive apps (taskillers, task managers, antivirus, battery apps, ram apps, etc)
I see that you have a weather app, perhaps uninstall it and then restart your phone and check again, that's quite odd.
I stand corrected
Indeed settings > security > owner info
Thanks for the correction. My OS isn't english.
thanks ! ! !
thanks ! ! !
