Yesterday I must have touched something on my phone and now this is what the screen looks like - this appears after about a minute of the phone being inactive. It still receives texts and calls okay, but to get away from this screen, I have to drag the lower circle to the right. The play, fast forward and rewind icons do nothing. What is this and how can I revert to my normal screen. I prefer the normal screen as it has easier access to my phone book, texts etc. Plus, this screen appears to be affecting the screen orientation function. Thanks for any clues as to what I have done and how I can undo it.
you probably added a new app, open your app drawer and sort them tap on the AZarrow on the bottom left -> Recently installed and see if there's any new music player
It's cured - thank-you very much!
anytime
for future reference follow this steps to backup your phone
settings -> privacy -> make sure both back up my data and automatic restore are both selected, and you can use this other options to make sure you don't lose anything
Make sure you backup everything using the Backup & Restore app
if you need the app you can use this link instead to download the apk
http://www.megaupload.com/?d=I5CJUPJV
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
