Where are the received files via bluetooth stored in Sony xperia U?
and how can i directly acess this files and also my internal storage i.e 4gb?
or simply from which option i can go receiving file>mnt>sd card...etc from menu.
Please help me anybody...I'm the new Android user,and i can't understand sony xperia U
's this type of internal storage.
Thank u in advance.
They go to "blutooth" folder in internal storage. There are subfolders for various types of files.
use any file manager to browse files/folders in internal storage.(Astro file manager is preloaded)
Thank U very much pradeeprk4,i have accessed my sd card storage.
please do one more help...please
can u tell me that how can i access Internal storage (i.e 2gb) from phone in the same way..
i.e, (Menu>phone memory... etc.) please help me.
i can't find it..
once again thank u.
That 2 gb space is only for installing apps you can't access it directly.
go to settings>apps>downloaded
or settings>storage to know how much free memory you have.
