I'm using the internet when my phone suddenly restarted. But it was stuck on Sony and Xperia Logo. Since then, my phone won't open. Please Help. What should I do and what causes this problem?
thank you
...if i have any othe question i will ask you here .....moreover i will tell you the results so other people will be helped too
Sure,good luck.
everything went great now my mobile works again ..... i'd like to ask one more question ....is there anything that i can do to help it improve its performance .....i mean it laggs a lot and i didnt even dowloaded anything !!!
thank you a lot again
You just need to wait some more after the repair,it will stabilise after some days.Also,do not forget to restart the phone regularly to refresh RAM memory.
You are welcome.
