Goodevening
Hi there hope not to take along from your time
My xperia SP while iam working on it is suddenly stop working and restart, Why?
Aslo want to knew how to active tracking mobile service while it has no Xperia™ > my Xperia
thanks for your time
Have a nice day
Thanks for your time
yes
my sp came with antivirus
shall i remove it
or do software repair
i will try remove antivirus
and tell you
uninstall not active what to do
thanks
Check if you have certain apps installed such as: Battery saver-app, Task manager, Task killer-app, Anti-Virus-app.
Uninstall those apps and see if the problem is solved
If problem still persists I recommend you to do a repair of the phone software:
Click on this link to get Sony PC companion:
http://www.sonymobile.com/gb/tools/pc-companion/
Start PC companion, start "Support Zone", start "Update phone software" and click on "Repair".
Follow the on-screen instructions
Still have the proplem after
making software upgrade
i am very sad on the money i spent to puy that phone
idid every thing and it still restart even software update fix
