Hello again. When I got my phone, when I wanted to choose a ringtone, I was offered two choices. I can't remember what the left-hand one was called, but the other one offered "Always" Since selecting Always, I no longer get offered the other box - can I get it back, please?
Also, how can I select an imported tone to use for notification of incoming text messages, please?
Thanks,
Geoff.
So, we meet again, Mr Alexdon. Thanks for your guidance. I've reset my apps, and now am back where I was initially. I've also chosen ringtones for incoming calls and text notifications. You're a star, alexdon, go in peace. Aren't forums brilliant, eh?
Yes,you need to go to settings-apps-all-media storage,clear defaults and you get the options again.
To select an mp3 as a ringtone,go to walkman app,tap longer on a song,set as ringtone.
We will meet anytime you have a question where I can give you an answer.You are very welcome,do not call me mr.Forums are great,keep coming by here.
i used ringtone from my SD card, but when the battary became below 4% it remove this ringtone and choose one of the ringtones bulit in the phone
is there are any solution for that
Well,try not to let your phone discharge completely,maybe your card unmounted and the sounds were not accesible anymore.
but why it didn't back after recharging the battary again :(, there is no way to fix this problem because it is some times is out of my my hand to let the phone discharged compeletly.
I am sorry to hear this.Do you use task killers or phone optimizers?
nop
Well,you should visit a sony service for further assistance:
http://www.sonymobile.com/global-en/support/contact-us/
