I am using a Sony Xperia s smartphone and some of my widgets are going mad. The widgets such as Go ex task killer, YouTube, Track ID, and smarttags are deforming. The track ID button on the widget keeps moving below the rectangle, the YouTube video squares keeps on going straight so all the vids arnt staggerd and the smart tag widget keeps on going small in size.
I would really appreciate if someone could get back to me asap... thanks!
you don't need taskillers nor antivirus, this apps create a LOT of issues. uninstall them asap. restart your phone and see if the problem persists, also are you using a different home launcher?
unrelated topic, if you have some time please check this thread
Thanks so much! That worked, they are fine now.... thanks
of course it did, I'm awesome
