I updated to ICS today.
And I found that when I connect my phone to PC, it would either take forever (15mins or more) to load the internal storage folder or it would show up as non-responding error.
Is there anyway to fix this.
run SUS again as this seems to be a driver (on your PC) issue
unrelated topic, if you have some time please check this thread
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Replug ur phone to another usb port. If cant, restart your phone and reboot ur comp and retry.
