I was writing a couple of very long SMS text messages and saving them as drafts and then going back and editing them over a period of time. Eventually one message was converted to MMS as it got too big. When I exited I had one draft SMS and one draft MMS.
Then later the second one was also converted to MMS but when I exited only the original MMS was on the list, the second had disappeared.
It would appear that only one draft MMS can be saved at any one time - is this true? I tested my theory by creating a 3rd SMS and converting it to MMS, once again on exiting only the original draft MMS appeared in my list.
Is there anyway I can find these lost drafts?
Many thanks
Duncan
I'm sorry to say this but there are gone, for future reference if you are writing long messages you might want to use google keeps then copy paste.
Bother! But thanks for the reply.
Anytime
