After upgrading the firmware on my phone Sony Xperia Ion(Lt28h) to 6.1.e.3.7, i am facing lot of problems with the camera, the camera came takes a lot of time to focus and the images are blurry,the quality of the image is worse. I request the developers to fix this issue and provide me with a satisfying solution.
issue fixed by flah and install firmware through flash tool. i flashed older version of firmware first and then flashed newer version. in both version camera looks better.
Please help me in fixing this problem
any update bro?
i think rooting the phone may solve the problem? what say?
how rooting can solve the issue?. software update after rooting too failed means?
also rooting will void the warranty rite?
rooting will not void your warranty, you can easily unroot your device by reflashing your firmware through PC companion or SEUS (flashtool if unlocked bootloader) unlocking the bootloader is the one that will void your warranty. root your phone and install this http://forum.xda-developers.com/showthread.php?t=1950862 im using it and cybershot MOD resolves the stupid camera issue sony wont even fix after releasing some firmware updates. hope that helps you
i tried rooting and installed rom manager to install CWM. but it doesnt worked. CWM not available for this model mobile kind of error i received.
can you explain me how to install cybershot in my mob. i'm missing something. really looking fwd to install this in my mobile.
how to flash through pc companion older version
