Hello every body.
I need help.
Was updating my phone with my computer with cabel. Computer whent into slepmode and the update stoped.
When I turn on the phone, the sign "SONY" are showed in the screen, for about 15 seconds. Then it turn off and starts all over again and again and again.
Have to press the on button and the turn up and down buttom at teh same time. That's turns it off. But when I turn on again, its the same.
What shall I do ?
Kind regards
Dals
Press and hold power & volume up until the phone turn off > charge it (wall charger ) for 1 hour or so > restart the update proces
Bingo, It work perfectly
Thank you.
Anytime
