hi got a xperia V that has bootloop, sony logo then restart....
i want to retrive the photos on the phone before performing repair. is there any way to do so?
Yes, you can press and hold volume down during the startup to start the phone in safe mode.
Since Xperia V have a phone memory and an internal storage. Your picture should not disappear when you are repairing the phone software as long as there are no errors in the internal storage.
Pictures are saved to the internal storage and it's the phone memory that gets wiped when you repairing the software. However, contacts, messaging and such will be deleted when you repairing the phone software.
Boot your phone in safe mode,see if that helps and if you can:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
If this does not work,repair via sony update service as there is no other way:
http://www.sonymobile.com/gb/tools/update-service/
oh ok. the strange is that i got it working once. but i was going to change the screen to so i didnt mind saving all pictures. cause i thought it would work. but now i dont seem to get it to start again.
so fo an Xperia V jsut press and hold volume down and power to get it in safe mode?
ok so if i use sony PC companion and the repair steps the photos should not disappear. im gonna try this tomorrow then
Yes, only data from the phone memory should disappear. But since you're having boot problems there is no way to tell if you have some errors in the internal storage which my lead to loss of data.
