I purchased sony ericsson live with walkman WT19i about 10 months ago, this morning suddenly it has gone into some sort of rebooting loop, i am unable to access phone, it is just shutting itself down and getting restarted again and again.
Whats the remedy for this problem.
Kindly help
regards
remove both SIM and SD card and try to turn it on
unrelated topic, if you have some time please check this thread
if that doesn't work repair it with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
i tried.... but i can't turned it on...
the phone doesn't have to be on with SUS
For update or repair,SUS is suggesting to set usb debugging mood.... But i cant open my xperia... what should I do now..:(
I don't see that "usb debugging mode" at all
I was problem auto reboot sony livewith walkman (Wt19i) but i have recover that.
Follow below step to solve that problem.
dowload update service center
1) http://software.sonymobile.com/update_service_setup
after download click on that or run .exe like Update_Service_Setup-2.13.10.201308300830.exe
and setup that and run
Before Update software please take SD Card Back Up (Using Card Reader Or another mobile)
now follow below step
a] Connect Your USB cable to pc but don't connect to phone.
b] Hold volume down key and connect your mobilet to cable.
auto detect your mobile and next wait for download software and setup software to your mobile
you will got message Software Installation Successfully.
than disconnect your phone and wait for 30 second and start your phone. first time your phone take some time...
Thank You.
Kindly help
regards
i have wt19i i flash it with pro it change from sony ericsson to sony
the proplem is it still rebbot
first the proplem come from i changed the charge soket
it rebbot give me the main screen for 1 second and after that it reboot
i remove the scket
it also reboot
please help
ithink that there may be a capacitor shortagr
but where i didd not know
