I'm not able to update my phone ... Even after installing SUS, I can't do it as SUS is not showing the option of my handset xperia u ... Kindly help me asap !!
Awesome let us know if it does work (it should)
Will it be updated to ICS ???
this phone will get by the end of July more or less
Ahhh ... I see .... Thanks a ton !! Another 10mins n download will be done
anytime, enjoy
Still no updated threads 😕 reli not happy
did you got your update yet?
there is one more Xperia U update issue.... When u connect phone to pc and files get downloaded via pc camp.. then xperia u shuts down automatically(maybe making it more convinient for us to straight away do volume down and plug usb back in) . But on pc camp u know it says shut down mobile unplug the usb cable from both sides and then plug back n press volume down key and insert ubs in mobile. At that point as u would think my phone is already shutdown so i just need to press volume down key and insert usb back in pc and update in mobile will start... But here this will not work and update won't start probably.... You have to ofcourse unplug usb from mobile and pc and then "Turn On" your phone once and then switch it off again,,, then keep volume down button pressed and insert usb in mobile then the update would get started! Its a glitch at present happening
SUS it's a far better option
i know, its just an info i shared .....
