I'm not able to update my phone ... Even after installing SUS, I can't do it as SUS is not showing the option of my handset xperia u ... Kindly help me asap !!
Hey, My Xperia U refuses to update via either Sony PC Companion or SUS.
SUS refuses to start. It just flashes " Configuring Network" or something like that and then proceeds to alter my network settings such that my Internet Connection stops working (<--- gets fixed after a restart).
PC companion, on the other hand, flashes "The Phone Update Component could not be started "
I Live in India (don't know if that helps).
The Phone itself reminds me everyday that a new software update is available (" Upgrade to the latest version of android .......... You need to connect your Phone to your PC for this update ").
Thanks.
Please post ur build number and other details
I'm sorry, Build Number over here means?
Other Details as in?
