Just wondering if there is an alternative to the "slide to answer" function on my phone. I would prefer a simple ol' button press. I have checked the settings on the phone and there doesn't seem to be anything. Thanks.
You have to download an app, you could get apps that allow you to press power to answer, shake to answer, etc.
OK, I'll have a look around. Thanks.
Anytime
