I bought an SP. The store where I bought it confirmed that its SIMLOCK-FREE. However whenever I launch my phone and enter my pin I get the following error : "Invalid Sim. Emergency calls only." " SIM card is locked. Emergency calls only."
I can enter my simcard-pin. It accepts it and I see the android 4.1 start screen and can swipe to unlock the phone.
I entered a code #*76....*#*#* and opened "SIM Info" This is what I got:
[x] Network 5
[] Network subset 0
[] Service provider 0
[] Corporate 0
[] SIM 0
This actually means my phone IS SIM-locked.
After emailing for support the store gave me a 16digit code to unlock my phone.
Now, where do I enter this key? Ive been youtubing/googling and everybody gets prompted to enter the code. I never get a prompt anywhere.
Question: How can I open this window/prompt so I can try to enter this key and unlock my phone.
Im running 4.1.2
C5303
12.0.A.2.254
Any other suggestions are welcome too!!
Stuff I tried:
- Tried using other simcards
- Factory reset
- On/Off
- On/Off
i am from india and now im living in malaysia . i buy here an xperia sp phone. and then i put an indian sim in it . it shows sony logo then the bootanimationthen again sony and boo animation and keep on . but it dsnt starting then an steting type logo appears and and loding box and then again same sony logo ...bootanimation ....
then i put off the sim and press the power on button without sim card and its on..'xperia sp is on'
again i power on it and put an malaysian sim asi was using it in same phone for 1 month ..and again it starting showing sony logo and soo on ,,,,but dsnt on...whats the problem....it can on without sim but can not with sim card plz help me....
Could your phone be locked on a specific carrier?
i think your phone is branded?right?
if yes then you must unlock bootloader to use another sim on it
Danial,my friend,as far as I know,bootloader unlocking has nothing to do with network unlocking.If you unlock bootloader it does not mean you will be able to use other SIMs.
i think so
it just not getting on with sim card
i check the sim lock with *#*#7378423#*#* somthing and it shows [ ] network 0 ....and [ ] and 0 in all other 4 options
If you do not get any [x],it is fine,no network lock.Download sony update service and repair:
http://www.sonymobile.com/gb/tools/update-service/
After this,try to insert a SIM.
thenks alexdon ..i hope this will help ....im trying it .....
Ok,keep us updated.
@alexdon wrote:Danial,my friend,as far as I know,bootloader unlocking has nothing to do with network unlocking.If you unlock bootloader it does not mean you will be able to use other SIMs.
i apologize for my mistake.
i take wrong between bootloader and netwrok lock
