I've been using my Xperia for a year (bought brand new), but today I've received message MM#6 and can't use phone! I've been reading forum and did what experts told to do (remove SIM, restart, even reset to factory mode), but still showing the same message! What should I do?
He reiniciado reestablecido de fabrica y aun nose como solucionar el problema. Me aparece mm#6 no valido al intentar realizar una llamada aparece reenvio de llamada activado.. Y no puedo configurar desde configuracion adicional...Ya no se que hacer
I have restarted factory re-established and I still do not know how to solve the problem. I see mm # 6 not valid when trying to make a call appears call forwarding activated .. And I can not configure from additional configuration ... I do not know what to do
GT
I've just run into the MM#6 message and I just got my ultra... But the fix too the problem is this... You have to get the phone registered too the network provider... As longs as it not sprint 😂 but that's it... Fixed my problem and I'm sending you this over the xa1. I'm sure I'm late but this will help others who enjoy the phone
I'm having the exact same problem and we will all notice it started Friday just past did u fifths problem
Did you manage to fix the problem with this product
I'm not send and received text and call
How do I remove a mm #6 error on my sony Xperia ax1 ulatr
Is showing network error please try later Iam on the uk and on the 3 network and it won’t update to newer software
My cx3 is off line and showing me some mm#6 stuff I don't understand what's the deal hear?
You need to get there phone too the provider and have them switch it to the the provider's services.. If you just put the sim card in... Over the course of a few days MM#6
