Hi!
I updated my active two days ago to 4.0.4. Today my upper left field with short cuts doesn't have the round shape it use to have, instead it has the shape of a folder, named "Xs" and it's empty! If I scroll the start page left or right the shortcuts exist on these pages. What can I do to fix this?
what happen if you long press on the folder and then you drag it to that corner?
share a screenshot please
can you show some screenshot?
press power button and - volume simultaneously
This is how it looks like.
That helped me sort of. I long pressed the folder and was able to move it to pages lef/right from start page. Then I just dumped it in trash and it disapeared. In upper left corner there automatically showed up a nice round shaped folder now containing my original short cuts.
Thanks!
I'm glad I was able to help
it just covered the corner shortcut. lol.
