Phone was working fine and since yesterday settings started to crash. When I try to open settings it gives a flashing view of setting menu and with in second it stops. ..
Repair the phone software using Sony Update Service.
Keep us informed.
Hi there,
Turn off the phone for a few minutes, then turn it on and check again.
I tried few times but it didnt make any difference.
try to reboot the phone is ok
