Hello,
I entered the service menu and did the speaker test. There is no sound, help!
but where is service menu?..i cannot even find it.. please:smileylaugh:
hi the loud speaker is not working on my phone also ringtone alarm etc
any advice please
@uliwooly-wooly wrote:This is how you enter Service Menu on the Arc, Neo, Play, etc
Open the Dialer and press this
*#*#7378423#*#*
Hi
i just bought yesterday sony xperia v(LT25i) water proof with 13 MP all these stuff in it but when i checked its IMEI number it told me that this is not a valid IMEI number what i should do or ther is any other way to check IMEI number and its also not supporting water proof option when i tap on it it says not supported whats the problem and how can i slove it first time usin xperia so dont knoe much about it
and how i can activate my proximty sensor if it's apear to be off...............????pls help me
You need to keep it covered,you will see it changes to on.
My mobile SONY Xperia Tipo shows that """""""""""unfortunetly camera has stopped""""""""
pls suggest...what to do..
Settings-apps-all-camera,force stop and clear data.Restart.
