My problem started after I used XRecovery to wipe th files on sdCard, system, data, cahce, and Dalvik-cache.
(But before that, I performed a backup using xRecovery and copy the files from SDCard to my PC)
When I was about to install the custom ROM that I want, the xRecovery could not find it.
I tried to restart my phone, now I'm stuck with the "Sony Ericsson" text display; and can't even boot to xRecovery...
How can I get back to square one? (2.1 update)
Please Help Me... I need my phone.
Please.......
You'll likely need to contact the people/forum where you got the advice to do the process.
Otherwise, awe can only advise that you try the official update service via our PC Companion software
try FlashTool
this is how
http://communities-origin.sonyericsson.com/message/112666#112666
(remove both SD and SIM cards)
