Helllo,
I updated my Xperia mini pro phone to ICS following the instructions were given in PC companion. After the battery removal, the phone couldn't start the OS anymore. There is always a picture with a phone with an exclamation mark. After that the phone shuts down and then restart again.
I followed accurately all the instructions! I'm really sad, because I would need my phone for my work and I cannot use it!
Please help me!
Thank you,
Aranka
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
or
Thank you for your quick answer and the link! I could reinstall the ICS and now works fine!
Good support, well done!
Aranka
