On Xperia V handset using the Smart Connect App: I added a new Event named "Charging Dock" and selected the Condition device "Charging Dock"
Using Smart Connect > How do I setup the "SensMe Slideshow" Start Action for the Charging Dock Event? When selecting "Add Start Action" there is no "SensMe Slideshow" action. I even looked under "Start Application", but I can only select "Album"?
I have scoured the internet to no avail, please help!!
That is a little weird, SenseMe Slideshow is available on my Xperia V's Smart Connect app - visible under "Start Application". Is your Smart Connect app fully updated? If not try to update it, or maybe try to clear the app data and see if that helps.
Try this
Settings > display > day dream > Turn it on > sense me slideshow.
EDIT : Not sure if you have that option there, I have it on my Z and you have V
Thanks for replying - unfortunately there is no "day dream" option under the "Display" Settings. I have looked under Themes etc as well. 😞
@Spartan08 wrote:That is a little weird, SenseMe Slideshow is available on my Xperia V's Smart Connect app - visible under "Start Application". Is your Smart Connect app fully updated? If not try to update it, or maybe try to clear the app data and see if that helps.
Thanks so much!! :smiley happy: - Updated Smart Connect App and now I can see the "SenseMe Slideshow"
Glad to help :smileysmileythumbsup:
