Where can i download the Android OS for w995?
please send me a link...
Does w995 works on Android OS?
The following handsets run on the Android OS:
X10, X10 Mini, X10 Mini Pro, X8, W8, Xperia Arc, Xperia Arc S, Xperia Neo, Xperia Neo V, Xperia Play, Xperia Ray, Xperia Pro, Xperia Mini, Xperia Mini Pro, Live with Walkman, Xperia Active, Xperia S, Xperia Ion.
Hope this helps
The W995 handset was designed around the Java platform. As this is the case, the hardware is not sufficent enough to work on the Android OS.
So this means that i cant install Android OS on my phone? They say it can be done but they dont know how to...
I can confirm that it is not possible to use the Android OS on a W995 handset.
No need to debate for it. I believe in you
Can i ask, what are the SE that can use Android OS?
Oh so this are all new SE's so todays SE are using android os? automatically when you buy it originally it is already installed in Android?
