I have a SE Xperia Neo V, and I need the .62 update, PC companion is no go, servers are overloaded.
anyone has the manual update?
and how ? Im actually quite new to SE phones
thanks so much!
You can try using Sony Ericsson Update Service, download from this link Aino™ - Update Service - Downloads - Mobile phones - Support - Sony Ericsson ignore the fact that it says Aino just select your model when you run the programme.
thanks suze!
it worked fine and smooth
Glad you got sorted. I prefer SEUS for updating my phones anyway so always a useful programme to have to hand. Enjoy your phone.
I'm gonna use that too, from now on
thanks a lot
