i have sonyericsson xperia arc s
orinal with android 2.3 .. excellent wifi ..
but a few day ago when i updat it to android 4.0 sic .. many problems with wifi connection ..disappear many times problem downlooad from wifi many times
my wireless router is tp-link model TL-WR542G ..
how can i fix the wifi in andrOid 4.0
OR
HOW CAN I come back to android 2.3
please help me
thanks
Hi, try repairing your phone's software and see if it fixes for you
remember all data on phone would be erased
It is suggested to format your sd card for clean installation and better experience
Update/Repair your phone via PCC OR SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
_____________________________________________________________________________
If problem still exists and you wish like to downgrade then
There are 2 stes to downgrade
1) Official ( if you want to keep your warranty ) - handing in the smartphone at a service centre you can request to have it re-installed with Android 2.3
2) Unofficial- Flash Gingerbread using Flashtool, your warranty would get void.
Here is how to flash using flashtool= see correct answer here
or
thank u very mich mr nabeel ... i reinstall the 2.3 ...:smileywink:
