iam using xperia p ,, my problem is that when iam opening timescape or gallery, my screne starts flickering i dont know why this shit is happening. iam having this problem from today morning.. except this my xperia is working fine!
suggest me what should i do now??
Do u have BIG FRONT App installed in your mobile? If so, Unistall that, Hope it may help u .
If the issue was not solved, Then try to repair the software with SUS or PCC.
and if none of raja's suggestion work, you should bring it to your nearest sony service center.
ok i ll try bt,, how does font effect only timescape and gallery???
Hi Please go through the below link, Hope u may find the Answer....
