Power button + volume down at the same time.Only that way it works.
Restart your phone,it has to work.The on screen option is gone after 4.3 update.
For everybody else it works,you are doing it wrong for sure.
And that is the proof that the screenshot function should have been left active in the power menu.
2.3.6 - Sony Ericsson - screenshot function available in the power menu
4.0.4. - Sony Ericsson - no screenshot function available in the power menu
4.1.2 - Sony - screenshot function available in the power menu
4.3 - Sony - no screenshot function available in the power menu
Has anyone asked users about what they want?
Are you pressing at the same time?power button and volume down,try at the same time to do it.Use two fingers and keep them pressed for 5 seconds.
