Hi
PLEASE help.
I changed the setting in accessability so that the phone speaks when you do something.
But now when I want to swipe to use it all that it does is say the time and battery level and I have tried and tried to swipe but nothing.
I tried turning the phone off and then on again but still nothing.
Thinking this must be a software fault?
Thanks
FTP
Hi FTP,
To unlock the screen and "swipe to select options" you need to use two - fingers> For selections use long - tap > for confirmations use double - tap.
Settings > Accessibility > TalkBack > Turn it off.
Cheers.
try to use 2 fingers to pull down the notification bar
Thank you very much helped me a lot
best solution my problem got solved
I wish to express my deepiest joy in helping me to fix or bring my phone back from the blind mode by your steps applied.
I wish to say thank you ever so much.
tookme2daystosearchforthishuggsx
