Hello ,
My screen timeout is not working even though I select 30 Seconds it’s not working and when I open that option again I always found that none of the seconds has been selected, Whenever I play the music if I get any sms the music will get hanged and then again it will start working properly but why my music player along with the music get hanged when I get any sms or any messenger notification? Even though I have updated my phone to latest version of adriod and still it gives me all this problem.
Kindly please help me out with this problem.
Thanks & Regards
Viraj
but that will be something out of my budget i guess... and i think it will be costing around 35
ARC is a good mobile, if you are not facing any problems then keep , if u want to shift to ARC S, no problem , but the difference is not that much, though ARC S is much more powerfull than ARC
SONY will be releasing many mobiles this year , if u can wait then u must.... :smileywink::smileywink:
i have ARC S
Well ARC doesnt have USB OTG and this is not woriking properly like how i discuseed above and even this hangs up alot sometimes and i wonder sometimes if i recive any cals this slide key doesnt work that time and call will reamins the same and im not able to recive it, like wise once this phone got wet completley and the display was totaly off i get it fixed with some amout and if u open the back cover and if you see there will be white color paper something like that but mine got red coz it got wet.
hehe
now u must definitely go for ARC S
ARC S does not have problems like this :smileygrin:
did u try repairing your software ???
are you facing any problem in arc s and one more thing i want to tell you is sometimes when i click the home button my icons are not arranged properly then after sometime it automatcly chnages the icon arrange things i orels i have to keep tapping on arrange icon.
no i am not facing any issue with my ARC S ... it is running flawlessly
software repair will fix this issue
