Hi there,
Press and hold "Power Button" and "Volume Down" at the same time a few seconds.
@alexrx wrote:
Hi there,
This should work fine on your device,the option has been removed in 4.3.
You´re welcome.
But I still think that the option to take screen shot after pressing the power button was pretty convenient. Is there any way that option can be added back?? Because taking screen shots especially involving the power button can sometimes get a bit sloppy. I had that same issue with Motorola Xoom.....
god knows, from where does Sony gets the input and decides to take away such useful features
You cannot add the option,you need to downgrade your firmware to get it back.
It should work,press power button + vol down at the same time.
