Hello my XPeria Play somehow activated the screen lock in my Pocket (it´s true!). How can I either recover it or do a factory reset?
Regards
Ben
Well, for Windows password recovery, you can ask for help with Windows Password Unlocker, which provides you an easy and safe way to reset Windows password on domain & local account for Windows 8/7/XP/Vista/2000/2003(R2)/2008(R2).
Get more from:
http://www.passwordunlocker.com/windows-password-recovery.html
this method worked for me, i lost my data but least i managed to upgrade OS of my xperia and what i lost i recovered by backup account.
hats off to you,
thanks a lot
hats off to you,
thanks a lot
i have forgotten my pattern lock so idownloaded pc companion and did till selecting the device then the pc
companion downloads update software my nets very slow it cant download it
it takes 1 hr to have a change in download can i download it in much better way
or faster like the pc companion did before
can u snd me the link frm where u downloaded the sofware update for pc companion
Does this work with the EXPERIA Z1
why doesn`t you add images to be more confident?
Why i cant install pc companion?
@iamjoclyn29 wrote:Why i cant install pc companion?
If you still can not install it , try other on your computer .
Get more from : https://www.recoverywindowspassword.com/
thanks
