Can someone please tell me how to save a photo from my text message to my pictures please?
I have attached a link form Androidzoom for the app, you could try using a barcode scanner app to scan/take a picture of the QR code to see if your phone can locate it on the market. Some apps are location sensitive and not available everywhere.
http://www.androidzoom.com/android_applications/communication/handcent-sms_flg_download.html
Let me know how you get on.
get "Handsent sms" from Android Market... should let you save pics..
Handcent is perfect for the job but just to enhance on the previous answer, if you long press on the screen whilst viewing the picture in Handcent then it will give you a pop up box and one of the options is to save to SD card.
Hi, thankyou for your reply...could you please tell me how to get to handcent please ... this is all new to me, a bit high tech..
It is an app that is available from the Android Market on your phone, however what I didn't check before is what your location is and if you have the Android Market available to you as it is not available everywhere (which I don't think is made clear enough to consumers when purchasing the phone in these locations)
I live in Melbourne, Australia
I found the Android Market but don't know where to find the handsent sms, could you please direct me in the right way....
Thankyou
Thankyou, thankyou, thankyou sooooooooooo much for your help....it worked.....I have saved my pics from my messages...I am so happy Suze.. thankyou again x
Yay! Doing the booty dance for you right now:smileywink: Glad you got sorted and can now save your pics. Just check that your Album can pic them up again for you to view them. If not shout and I can give further advice.
