Hello, I (my daughter) inserted a screen password protection, by creating it somthing went wrong. How can I reset the password. Without it I can only switch the phone on but not answering any call.
With PC companion I updated the sowtware but the password protection still remain.
Many Thanks
max
you can use Update Service, but it will delete apps, sms, mms, contacts, settings
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
make sure to mark the Correct & Helpful Answers
Wonederful, it works!
I'm glad its working now
