By mistake, I seleted "call from phone" as my default dialer. I want it to reset it so i can select from diffrent dailers while calling. I dont want to reset my phn to factory settings, so any suggestion other than that will be apriciated.
This is very strange.I wonder why the others do not show up.Are you willing to try a software repair just to reset to default that app?
goto setting>apps>downloaded...tap on setting (upper right)choose reset app preferences
Try the upper suggestion,if it does not help,try:
settings-apps-all-media storage-clear defaults.
i followed setting>apps>downloaded...tap on setting (upper right)choose reset app preferences, but still the same.. whenever i click on call, it doesnt ask for skype or MVOIP.. it connect through phone dialer..
settings-apps-all-media storage-clear defaults is not enable .. its already default i think.. any other suggestions please..
Settings-apps-all-phone,clear defaults does not work either?
Settings-apps-all-phone,clear defaults is already disable.. it shows no default set
Settings-apps-all-settings-clear data and restart your phone.
restarted with all the above prcedure follwed, not working
