After the SMS conversation or message is long-tapped, a context menu appears. It does not contain option to dial/copy the sender's number, show the sender's contact info or add the sender to contacts, which would be very natural. I know that there is a workaround via "Edit senders", but it is not intuitive and requires more taps.
Could you please add the following functionality:
- dial the sender's number,
- copy the sender's number,
- show the sender's contact info or add sender to contacts
to the context menu displayed after the SMS conversation or message is long-tapped?
I think it would be a small and easy, but very useful change.
(I am using Xperia Mini with ICS 4.0.4, firmware 4.1.B.0.587)
Thanks a lot for your feedback ;-).
